Bob Quale
- Nov 24, 2004
I want to put a 2inch handle bar riser on my 99 700SX. Does anyone know for sure if the cables are long enough? and if not, what cables would I need?
Thanks Bob
Thanks Bob
sandmanmike1
Cables will be fine. You may need to cut a zip tie and move a cable but no extension will be needed. I re-installed a new zip tie in a different location. If you do move a cable or wire make sure it will not rub on anything and cause a short.
