Bender Transfer Rods
yamaha98sx700
Queensbury, New York
Does anyone know where I can get replacement o-rings for bender transfer rods? I beleive they are silicone o-rings. What should I use for lube when I put them back together?
I also need help with lube for the wheel bearing in the rear skid. Should I use the yamaha low temp. grease, or just a good water resistant trailer wheel bearing grease? I am afraid that the trailer bearing grease won't work at low tempratures.
Thanks!
just call your dealer and ask. i personally would use the trailer grease in a bearing because that bearing is going to warm up with friction. i think the low temp would get to thin, but i could be wrong. some one else should chime in though.
I sent mine t0 Bender when I had them and they put them in for FREE plus lubed them. Give them a call.
Low temp waterproof grease. Go get a O-ring kit from a autoparts store for 10 bucks. You can never have to many orings.
I tried to match up the O-Ring on with a kit at work, it is a smaller diameter cord than a standard o-ring. I could order o-rings from mc-master carr, but i would have to order large quantities. I was thinking about checking with the local Fastenal store.
