EricMichael
hey guys the stuff seems to work pretty good..no leaks yet...but I gotta say what a B&*^% it was to get it off my hands...they should put a warning on that stuff
viper48
I used that yamahbond stuff when I put my bender pipes on, that stuff is the same way. I had black hands for a week. YUCK!!!
..SNAKEBIT..
your not supposed to put it on your fingers just the pipes, you need to wipe it off right away and not on your pants! (got work pants with gops on them)
if in doubt next time wear some rubber gloves, yea permatex makes those too!
lava soap takes it off super easy.
After all is just silicone...clean dry rag will do the trick or you can suck it up.....
Skidooslayer687
I know it sounds disgusting guys, but if u spit on your fingers before you put it in the silicone it will not stick. Theres a chemical in saliva that prevents this, easy to clean up that way just wipe it off with a rag
EricMichael
yeah..i just put the permatex on and wiped it around the joints with my finger...wasn't thinking it would stay on even after gas treatment
