2007 Phazer Mountain Lite Exhaust Fix
uptime
Michigan Upper Peninsula
Love the new sled but the exhaust will roast anything on that extension.Came up with a cheap fix for $10.00, go to the muffler shop and have a 1 3/4" I.D. pipe flared on both ends to 1 15/16".Then have it bent to a 45 degree angle, cut in the bend at desired spot.Fit the piece on the muffler and put to self tapper screws to hold it on.If the flare fits to loose use a muffler clamp on it and crimp it to fit snug then screw to mufller.You can see the bag in the picture is not roasted after 200 miles.
great fix should be o 08 upgrade. havent we seen this problem get solved on the new mnt sleds?
Pat
