Lyle, heres a easy solution, tell him to send me the 3 powervalves and I will give him $50 for the 3, I am right here in Ohio and hes close, this way he gets his money back and some free cables and I will use the valves for a big bore. Tell him to pm me and I will either paypal the money or send him the $ whatever way he wants it.
Problem solved for both parties.
What if you tell him that you wount refund unless he goes to the dealer and gets an honest opinion from them?. But then again he might bring some other valves that are bad.. . Gees I ain`t that smart afterall.
Anyway, this suck. The guy probably doesn`t have that much knowledge and thinks that everything should look mint in order to function.. .
Good luck
Good luck
thanks don, gone blue can let him know. you are a great guy to do that, thanks lyle
marty
Sorry to ear this SXRSIST. I've been in the sales buisness for years and they'res some people you just can't pleese.
I just hope the stuff I get is the same parts Lyle sent to him. Maxdlx
did you buy that stuff paul?? should tell him to show us the receipt for his new one.
paul , i l shoot you some money if its not worth your 50.00 ok
Don't worry about it, if only one cable is good it is worth it, especially the mag cable. LOL Paul
Lyle
I got the valves and cables today. The worst cable there is still useable. the little fraying that is there isn't that bad. 2 of the valves look like mine, in perfect shape. The one does look a little suspect where the cable goes in, but I couldn't get the cable to pull through it. So unless all 3 looked the same and maybe he swapped the one out, they all look like just as described to me. They need a good cleaning, but hey thats easy enough. Paul
thanks for clarrifieing that paul, man i was a little worked up over that. at least something good came out of it. try to help someone out and what do you get, stiffed. again, thanks paul. lyle
