what track? what gears?
BETHEVIPER said:eric, matt has my timer, it velcros to your sled, tell him to let you use it. unless you have a sled to run against that is similar your just wasting time. if you use the timer you can see what works for real, not feels like.
those chisles are not very safe for trail riding, you may want to install picks on the outside.
mrviper700 said:ahhh, dont put too much faith in the ol butt dyno, what feels fast is usually slower!! The reason the slower feeling set ups are usually faster is the sled simply squirts forward, covering ground at a faster rate without all the wasted motion of rearing up and wheeling like a bronco at a rodeo.
First thing I dont like very much is the hauck spring, why have a 55kg start spring in there, do you want a high engagement speed for some reason?
The ending of the spring 135kg is pretty stiff as well, a little softer shift on the spring will make your weights act a little heavier effectively loading the motor more. I think I would try the stock y/w/y spring 45/128
As far as the helix goes you need to set up the primary first to run your rpm correctly, then fine tune the shift with the helix, you can move the rpm up or down a 100 rpm or so by the finish angle on the helix, meaning: lets say your running along and the tach says 8800rpm all the way thru, if you wanted to gain another 100 rpm you can do either of the following, youll have to test it to see where it makes the most differance (1.) you can twist the secondary spring up 10 degrees, advantages, better backshift, possible loss of topend mph (2.) you can lower the finish angle a couple degrees, advantages: squeezes the belt more on topend and requires less spring force to hang onto the belt, may over rev requiring more weight in tip of weight.
