yamaha_snopro
i got a new set of light weight radius rods and was going to use the stock inner ends and need to get 4 outer rod ends that will mate up with my stock trailing arms where is a good place to get them?
kysledneck
Metric can be found in McMastercarr, bearing dealers usally care them..but yes you wont find them for under $30.00/ea.
I did the same..went standard. The difference in I.D.s for the bolt to the trailing arm was so close you wont have any problems with fit.
