best place to get outer rod ends?
yamaha_snopro
Northport, MI
i got a new set of light weight radius rods and was going to use the stock inner ends and need to get 4 outer rod ends that will mate up with my stock trailing arms where is a good place to get them? :2strokes:
I had the same problem! Metric was so high I had the guy tap my outers with inch size & just drilled out my trailing arms to 1/2"! You can search all you want but metric rod ends are about $40 a pop! These are chromolly about $9!
Metric can be found in McMastercarr, bearing dealers usally care them..but yes you wont find them for under $30.00/ea.
I did the same..went standard. The difference in I.D.s for the bolt to the trailing arm was so close you wont have any problems with fit.
