gas and oil cables,ext
allblkviper
Fenton Mi
Looking to put mountain cables on standard sxr 700 w/6" risor.Will mountain cables be longer than stanard so I don't have to used those bulkey extensions? Thank you for your input in advance :2strokes: :letitsnow guys
I found this in another post:
yamaholic22 said:
The tors problem is most likely from your throttle cable being adjusted too tight. Try loosening the cable adjustment and it should go away. The other possibility is that your riser is too tall for the stock cables, and it is putting too much tension on it causing the tors switch to activate, stalling the engine to below 3000 rpms. If that is the case you can get throttle and oil cables from a mountain max, because they are several inches longer and will accomodate most extensions easily.
So I think you've got the right idea. :letitsnow
cables
The stock oil cable off my 01 SXr 700 is long enough so is the Emergency brake cable but you need a throttle cable off of a mountain Viper. You will also need a longer brake line hose.( Cables routed through centre of air box under snow screeen ) You will be really tight with your wiring and should extend wires also. I am using a Rox adj 5.5" - 7" riser. It is great with a Boss Hi rise seat.
