dirty stuff
super clean
I use super clean you can get it any where it comes in a purple bottle.Long as you clean it everyonce in a whil it comes right off don't expect it to come off very easy if you let it got for a year.
Grease Lightening. Can be found in the cleaning section of most any store.
Spray it on, let it sit, then hose off. For areas that have a heavy build, use a scrub brush after letting it sit on the surface for a minute or so then simply hose off. Works even better on the trailer arms.
YS
We've used laquer thinner or carb cleaner. It takes most of the oil off and makes it dull at first but, we've found that spray on tire foam really shines it back up and stays that way.
Good luck.
