reddog mmax 700
hey guys what do you use too get the black stuff off the belly pan from the exaust? i've been useing a toothbrush and sunlite soap but it's not helping....reddog
super clean
I use super clean you can get it any where it comes in a purple bottle.Long as you clean it everyonce in a whil it comes right off don't expect it to come off very easy if you let it got for a year.
YamiSmurf
Grease Lightening. Can be found in the cleaning section of most any store.
Spray it on, let it sit, then hose off. For areas that have a heavy build, use a scrub brush after letting it sit on the surface for a minute or so then simply hose off. Works even better on the trailer arms.
YS
YS
Westley's tire bleach works pissa
redsnake3
i used speedball on a buddies mxz that had a yellow belly pan, came out perfect. the speedball is more industrial i think.
iahacker
We've used laquer thinner or carb cleaner. It takes most of the oil off and makes it dull at first but, we've found that spray on tire foam really shines it back up and stays that way.
Good luck.
Good luck.
T.S.U.Filmz
Maddogs700srx said:Westley's tire bleach works pissa
also Gojo hand cleaner without pumas.
03viperguy
I am with maddog, bleach white is the balz. stuff works amazing on a LOT of different thing
viperking
bleach white is real good
