..SNAKEBIT..
ok my rollers are pretty loose on the mounting tube
looks like the bushings are worn, how loose can they be?
Running a 02 CPR piped viper
8dn-10's for flat land
8ek's for the mountains
should I replace them with the stock 14.5mm roller?
or buy 15, 15.6 or something else?
any good used ones out there?????????
bushings
check your sheave bushing and cover bushing if them are worn that can cause yor rollers to take a crap
..SNAKEBIT..
ok Ryan how much is to much been a while sence I had a new one?
so should I just order all the new clutch bushings (secondary also)
and new 14.5 rollers right from Yamaha or ???
..SNAKEBIT..
anyone ? prices?
shoot me a pm?
shoot me a pm?
98srx6
Have a set of 14.5mm rollers...25$ shipped.
There's your rollers.You have to dissasemble the primary clutch it's threaded together.I don't know if you ever done one but they do make rebuild kits that include the slider in the tower to .The dealer should be able to do it in under and hr unless you know someone near you that has the tool.
..SNAKEBIT..
so if they fill loose I should just go ahead and rework it
..SNAKEBIT..
98SRX6 I PM'd you I will take the rollers
yes if there's play re bush it.
