xtc700jeff
heel clicker weights ( anybody help)
Need suggestions on heel clickers .I have a 1998 xtc 700 it has bender pipes ,the head gsk mod done( before i bought it supposedly),reed spacers ,boyensen power reeds,boost bottle.Rocket Roller 2 secondary from maxxperf with 52/38 helix 60deg. on the spring.Ripsaw track with 144 1.325woodys and 8 tooth drivers with gears changed to to keep the same ratio.I have a primary from a 2001 with 15 mm rollers. What would be a good set up for heel clickers STS3HC 40-10y as far as weight in heel ,center and tip?? For this sled ??? THANKS
That helix; especially with a roller is gonna hamper properly setting up your clutching. You need something around a 48/38 non roller or a 46/36 roller. Your too steep on initial angle. Been der dun dat...owned 3 Bender piped sx,s with heelclickers.
xtc700jeff
Turk, what weight set up should i go with ? With the 46/36 helix??
4 grams heel & tip would be a good starting point.
SWEDE
Jeff, did you get my pm? I am from Grayling also, small world huh?
xtc700jeff
grayling
Swede, i got your pm .Sorry i didnt reply right away ,got side tracked . pm'ed ya today thanks for the info
xtc700jeff
turk
hey turk ,i think i have the helix problem worked out just waiting to hear from pioneer perf. thanks for the advise
SWEDE
Your welcome, I hope you get everything dialed in, sounds like you have a sweet and tricked out machine. Mine is fairly stock, just massaged clutching and jetting and a m-10, later Josh.
SWEDE
Jeff, I pm'ed ya
Allvipedup
Just make sure those weights ARE NOT the powder coated clickers, my mechanic just showed me over 20 sets that have blown up or were on the verge of blowing up. They don't shift out all the way and counter balance themselves to the point of detonation due to the heel angle. Mine were a ticking time bomb ready to go at any point. He pulled them and set a similar weight configuration with Yammie weights. Now it shifts out all the way and pulls like crazy. Just FYI.
xtc700jeff
Powder coated ?? never seen any that were powder coated ,what do they look like?? got any pictures. The ones i have dont look like any powder coating has been applied at least not any powder coating that i have ever seen.send pics
Allvipedup
Sorry no pics. Basically, I was told not to use any of them, but especially the first generation, black ones with the rough black powder coat on them. The mechanic I mentioned earlier "Doc Fang" said they are a nightmare. I trust him, with 25+ years as an engineer and racing. He said just use the stock arms and adjust your weight accordingly. I'm sure they're are plenty of guys that will say he's crazy or whatever, but I saw the proof and decided to go with the system this guy has proven over and over again. He has a dyno and is a rep for almost all the major after market and oem's. He tests a lot of the products. I learned more in 2 hours then I've learned in 2 years.
xtc700jeff
heel clickers
Turk, i just got my helix's.PLEASE HELP
