Gauges sxr to srx?
redrider24940
Kiel Wisconsin
Does anybody know if the speedo and tach off of a 2000 700 sxr will fit in a srx Gauge pod? And if they only fit in certain year pods what years they are. I don't Know if the speedo and tach were different between an sxr and an srx in the same years. Any help?
Why wont the tach work? Would it work If I just used one of the headlights? Or is the tach all together different? The dual headlights glass is clear and i don't know if the single light is clear. The dual headlight looks like the glass is plastic and the light comes out better. I know to run both headlights it would require stator plate work. This is a pod being converted to a 97 sx to remove the old pod, headlight to get more light, and gauges.
This is the exact same thing I did a few years back. Get the single headlight pod with the big gauge openings. The dual head light sleds have a different electrical system and the tachs are not compatible. Also there is not enough watts to power both headlights with a 97 stator. Look at the last picture in my avatar.
