do not do this mod to your sled if you are trail riding it.
there are a couple things wrong here.
1 the w arm is in upside down and could destroy the shock, lower mount, rails and track.
2 adding the wheels in the middle will only work for grass racing. the arms that run up the side of the shock as well as the mount for these arms will hit the tops of the wheels before the arm bottoms on the mount. when the arm bottoms there is 1in of clearance between the mount and the track.
i have a similar setup on a skid for grass drags and even at the drags it will hit sometimes if the track is rough and chew up a wheel.
i sold parts to a guy that used one set of wheels like this in the middle and he destroyed both arms and the wheels.
if you run a small wheel up front, a shim kit from pioneer or larger diameter wheels and stop looking at your slides they will last for ever.
hope i have saved you some down time and money as well as anyone else who has thought about this.
