B buck srx 700 New member Joined Dec 18, 2006 Messages 8 Age 51 Location mass Jan 6, 2007 #1 There is a noise coming from the spare belt. When it idiols down she rattles. But when i take the spare belt off i stops. Any thoughts thanks
theblues New member Joined Mar 28, 2006 Messages 736 Age 62 Location Ottawa Jan 6, 2007 #2 Check your motor mount...could have a broken bolt...also your offset could be out, is there wear on the sides of the belt...how's your center to center...check the side to side lpay of your secondary...could have worn bushings...
blue missile New member Joined Jan 2, 2006 Messages 542 Age 56 Location bucksport maine Jan 6, 2007 #3 i've been told there needs to be some side to side play in the secondary. so how much is too much?
B blue fun New member Joined Jan 10, 2006 Messages 12 Age 55 Location mn Jan 6, 2007 #4 are the rivets that hold the belt clips loose?
Concept Carbon New member Joined Jan 31, 2006 Messages 1,188 Age 45 Location Ottawa, ON. Jan 6, 2007 #5 check the riviets there prob loose
