suspension spacers? need some help
Rochester, NY
been looking at the yami drawing for the rear skid, but cant make heads or tails out of it.
i think im missing a spacer in the skid, hoping someone can check and let me know what im missing.
on the upper shaft, where the guide/idler wheel and the transfer rod meet how many washers and/or spacers are there between them.
if someone happens to have them sitting around can you tell me the specs-thickness.
i must be missing something because i have a wear mark on the transfer rod from the wheel.
thanks
i belive it should go from the torque arm out. bushing, washer, wheel, washer, transfer rod with bushing in it, metal spacer. but both washers may go befor the trasnfer rod but i dont think so
