spainman61
The clutch engages at 4200 the way it is setup.. The rpms go from 8500 off the line and climb to close to 9000. I need to get them down, I do no that.. If I run the silver secondary or red, and put some of the heel weight to the tip that should help with the overrev right?
mrviper700
VIP Lifetime Member
with the set up I gave you or Bob's? if its mine, then yes take a little bit out of the heel and apply the differance to the tip. Keep the green spring in there as long as its not overshifting, telltale signs would be when sled gets out 50-60 ft and rpm is say 8100 and then loses rom for a brief time then begins to climb up again. The looser the secondary spring the faster the sled is if it doesnt overshift.
