yamaracer18
will a studded 1.25 inch track fit a viper? with out and problems
grooter
I Bought A 02 Viper Last Year From A Guy That Had Installed An 1.25 And The Track Actually Had Worn On The Front Heat Exchangers! Some Guys Have Said You Can Do This If You Remove The Protectors As Long As You Dont Studd It!! If You Do Stud You May Have To Change The Drivers To A Smaller Size. Iguess You Have To Way Your Opptions. Good Luck.just Remember Blue Rules
ephnright
To stud 1-1/4" track on a viper you need to got to 8 tooth drivers. If you do be careful still, I have a studded 1" track on mine and have digs in the rear hx from hard landings.
yamaracer18
ic another question for yas is will a 14" wide track fit
redsnake3
yes
yamaracer18
the boggie wheels wont be faling off it?with the 14" track
redsnake3
no, they will be at the edge, but on.
