srx 150KMh MAX at 8300?? what's wrong again :(
have you checked the connections between the fuel pump and the crankcase? the spring clamps don't seal well especially as the hose ages. copper wire wrapped around a couple times and twisted tight works well. could be your not getting enough fuel at high rpm.
Fortress.. check your spark plug wires and caps. I had a bad cap which kept cutting in and out,took forever to diagnois.You may also have a bad coil. Don't give up,its something simple your over looking.
yammawolf said:
Fortress ????????? what year srx are you running.this will help with the diagnoses if its a 2002 srx it can very well be in your detonation circuit (timing retard) controled by your cdi as well.
its a 2001
i use standard bre9!! well, it become worse, now it pull to 8000 and slowly decrease to 7800 7900. 140 145KMH.. Same thing as last year!! I did try to disconnet the servo motor and keep the powevalves open and its not better.. Same thing
I'm sure its electrical, but think i have done all i can do for this :(((
You need to be running br9ecs as plugs.
Are all your power valave hooked to the cables?
Are your cables hooked to the servo motor properly?
My sled ran like crap untill I discovered PV were all pulled out ( don't know how ) and the cables going to the servo motor were on wrong. Have you rev the motor and actually watched the servo motor move and actually pull the cables ?
Also when you have the cover off the servo and all the power valves off the engine physically twist the ( motor off ) servo motor and watch all the PV move. Make sure they move all at the same time and same distance.
