nightmanx1
who ever wants a copy let me know. I have a Exciter factory man. and would be willing to send the a copy aslong as they shipping for the cd or i can email it but email will take a few days to get it all to you.
Vmax540
thats what i'm talking about the inside setting pump stroke,nitris223 said:Checked the cable and it was set right. Dot was just showing. There is something about pump stroke , washers inside the pump or something. I don't know what I spend more money on, plugs, oil, or gas.
Could some dumba$$ put a different cable on it.
Is there anyway of running it for so many minutes, certain rpm, equals so much oil..
Could I run the sled in the garage with out the air box on.
yea you can run it a little with out the air box on,it may want to
run lean so becareful,
take nightmanx1 up on his offer and get that CD manual!!!!
nitris223
nightmax1 sent you a P.M
Vmax540 sent you a e-mail. on Ebay site.
seca
i had a 93 ex570sx that was much the same way. plugs were always black as tar!! the last thing i replaced on the sled fixed it , and it ran savage!!!turned out to be my plug caps!!!just for the hell of it , remove yours and put an ohm meter across them . should read 5 ohms i belive.
nightmanx1
I need an Email to send it to
nitris223
Well I won the oil pump on ebay, just need to wait for it and then try again. I hope this solves it.
nitris223 said:Well I won the oil pump on ebay, just need to wait for it and then try again. I hope this solves it.
keep us posted,,these ex pumps seem kinda hard to get dialed in(adj.),
but definitely doable..it will be easyer when you get the man...
Carb specs. for '88 on;
M/J 320
P/J 42.5
Pilot outlet 0.8
air screw(turn out) 5/8
Power jet
left carb 160
right carb 200
Float level 17.1 to 19.1mm
M/J 320
P/J 42.5
Pilot outlet 0.8
Power jet
left carb 160
right carb 200
nitris223
no power jets on this one. Just staright mikuni's.
Thanks nightmanx1 for the info on the oil pump. Do you have this on CD in PDF format. If so I am interested in getting a copy.
I have CD's of the 700SX ,SXviper, Mountain max and also a CD of the 600 non power valved sleds. Any body needs something let me know.
Shoot me a email at newfy@sasktel.net
nitris223 said:no power jets on this one.
Thats what the book is saying 1988 and on power jet L/R listings(mikuni vm
-38 ,shows it in the pic. too..
what kind of 600 N/PV sleds does your cover(years?)
nitris223
It covers 600 triples
02-03 Mmax
02-03 SX600R
02-03 Venture
02-03 Vmax
I should have this CD today hopefully. This should also work for the 600 Venom for some things.
02-03 Mmax
02-03 SX600R
02-03 Venture
02-03 Vmax
nitris223
I think there was a bunch of changes from 90 to 93 with the carbs.
Could have,,yours a '90 right??
nitris223
Mine I think is a 92. It's not the 93 sx. Could be a 91, I would have to check the registration. I have 5 sleds and it gets hard sometimes to remember all the years.
CD manual didn't show today , maybe monday.
Thanks nightmanx1 for the rest of the manual.
nitris223 said:Mine I think is a 92. It's not the 93 sx. Could be a 91, I would have to check the registration. I have 5 sleds and it gets hard sometimes to remember all the years.
did you get my PM??
nightmanx1
not a problem it is for an 88 or 89 but the settings should all be the same. I know my 87 came with the VM38 carbs and not the butterfly carbs.
