Quick clutch question, might be stupid.
cacsrx1
Highmore SD
Trying to help a guy out, he has a 600 twin that ate the primary clutch. I found a primary off a Rx1, would it fit a 600 twin? Dealer wants to stick it to the poor guy.
what year 600 twin. the weights and springs will be wrong, but the clutch should work. Maxdlx
Taper is the same. The only thing it will have is a long spring cover so you will need to find the equivalent spring in the new LONG cover primary spring chart. For a rule of thumb, never overhaul any of the 500 or 600 twin primary clutches. Once they wear out the first time you will continue to wear out the rollers & weights every 200 miles!
Ya I know what U mean, the guys around here ride then till they wont pull themselves anymore and wonder whats wrong. lol. This one has the typical flat spotted rollers and ruined weights.
