Raced srx tonight
pretty sure it will rub against the heat exchanger protectors(non removable)at the front of the tunnel...
mr.viper/BTV some of the lugs have shapes like this ^-^ shoudl I just cut it flush with the bottom line?I cut it flush with that middle lug and I believe its still rubbing, will try tightening up track tension tomorrow, but if that doesn't cure would it be safe to take alittle more off?or would that hurt traction to much?also mr.viper before i cut the lugs i did try diffrent track tentions..even tight tight and it still was rubbing even at say 35 on the stand so I cutthe fingers down over the windows jstu a bit and noticed a big diffrence down low, but can still feel some vibration higher speeds 90+..thats why I was curious on how much is too much..was kinda worrying about studs hitting
what you want to do is the math. you know how deep your guards are, you know how far your studs are above the lug, you want tot have 1/4 of safty spacing left, everything else is just rubber that is slowing you down.
