1992 Phazer 2 fouling plug and occasionally stalling
zooman
Cameron Ontario
I have taken the sled out for a few rides this week and a couple of times this week it has fouled the fan side plug a couple of times. I have put new plugs both times and it did the same thing. I have taken the carbs off and given them a good cleaning before I tried to ride the machine.
The sled also has stalled on my a few times. I will be riding to a stop sign and sometimes it will just stall or it will bog and if I flip the choke half on it will rev out again and I kick the choke off and away I go again.
Any ideas guys?
Matt
Check plug wires!
I would check your spark plug caps and wires. I would simply replace the caps and if in doubt do the wires too. I have had sleds that did this and turned out to be a bad cap.
Well I am not trying to get anybody to chase post, I am just anxious to figure out this problem. We have about a foot of snow and I have my first trail pass.
When you are checking for spark is it safe to ground the plug to the motor like we can with older sleds and not hurt anything?
I will check out the plug caps this morning.
Matt
Problem fixed!
Hey guys thanks for the help. I decieded to take my sled to get looked at and the shop cleaned the carbs and now the sled runs excellent.
It was the low speed jet on the right side was pluged. I guess when I used carb cleaner it wasn't enough. But now the sled runs excellent.
I just wanted to pass the info on.
Appreciate the help fella's.
Matt
:letitsnow
