help with installing ohlins extensions
01&02SRX
Grafton Mass
Hi I just got a pair of ohlins without reservoirs and need to install the extensions i have no directions or ideas and do i need to have them recharged after or do they go on the other end any help is greatly appreciated!!!!! Thanks Stan
:letitsnow
Yes Mike went great just fine tuning and trying to put these ohlins together and should have pics real soon thanks a lot and I'll be in touch
The heims are loctited on,I had to heat them and use a tool that you put in a vice to hold the shaft without damaging it, advantage sells with the extensions they sell,I am sure there are other ways but it was a pane in the *** even with the proper tools.
Steve
find a lowes or home depot, and look for a piece of 1/2 by 2 aluminum flat bar. Drill a hole in it exactly the same size as the shaft or a tiny bit smaller. Then cut it in half right throw the center of the hole. Put the shaft in the hole, put the bar in a vice crank it down, and use heat to get it off. The end of the heim has a piece in each side that will come out, and a rubber o ring on each side. Maxdlx
Thanks for all your help, extensions are on and shock installed I used wood drilled it out, cut it in half and a little heat went a long way! Thanks Again Stan
