help with installing ohlins extensions
01&02SRX
Grafton Mass
Hi I am trying to install ohlins shock extensions and can not figure it out any help would be great Thanks Stan
what is the problem you can't get the heims off. you need to remove the bushings, make a shaft holder, and heat the eylet some, they will come off. Maxdlx
