help with set of for grass/frozen dirt drags
terret725
berkshire mass
theres some dras this ween end and i gotta shut up my buddy on his f-6
this is what i have to work with so far. sxr700 with PI center dumps. i have the twin boots on so i can put a boost bottle on after i make it. i cleaned up the exhaust ports matched it up to the exhaust flange. didnt touch the cylinder side tho. jetted 138.5, 145, 145 with screws at 2.5 out. pilot and needles are stock.
clutch 89L weights. ysy primary. 47(i think maybe 45) helix and with a stock spring. also have a red secondary and a few shims to play with.
suspension. feet bros(i think cant remember) transfer rods.stock rear shock. 02 viper center with a spring off at SX front shock. straps all the way out. transfer rods at the second to last line. FRA at med. im puttin on some new hyfax. also have a set of sx shocks and a sxr center.
any body have any ideas to help me out using what i have or something i could easily get at a dealer. also have access to alot of polaris parts passably. im not sure if the primary springs are dif size or not but i have access if they ll work. also have access to jets.
temp should be around 28 give or take. and around 1000 feet above sea level.
any help would be appreciated.
