Trailing arm compatibility?
Viper Sniper
Northern Illinois
Are the T-arms on a 1997 vmax SX700 the same as on a 2000 SXR700? Coloris not important, just want to know if the shorttravel arms will work on a long travel SXR.
I'm 95% certain they are different caster angles. Try searches. I think its been posted. If not I can look it up tonight.
Your right 23.5 vs 25.5.. If it did not make a difference they would not have made two of them. I think two degrees caster is a lot of change. At least in a car. MM had a different shock mounting bracket angle also.
..SNAKEBIT.. said:
but most cars have 7 or LESS degrees of caster, so 2 degrees is more than a @ 25% change
Yea you are right.. But its not a rubber tire on asphault trying to over come the tire patch. Its a 2.5ft long ski right? 2degree is still around 10%..
You maybe right that you might not be able to tell but I bet it will steer differently maybe imperceptably. I would just not mix one side to side.
