grooter
WELL WERE GETTING DUMPED ON WITH LAKE EFFECT FINALLY!!! SWICHING FROM YAMA-LUBE SEMI SYNTHETIC TO AMSOIL INTERCEPTOR! IS IT OK TO MIX THE TWO OILS??? IM TRYIMG TO LET IT GET DOWN AS FAR AS I CAN BUT DONT WANT TO GET CAUGHT WITH MY PANTS DOWN
chadg
Yes it is ok to mix the two oils. Amsoil will for sure mix with yamalube and most other oils. I did it this year and it was fine.If you have powervalves your sled will jump up and kiss you.
do a search on oils there is alot of great info on this site.
Chad
Chad
grooter
Swithching Oils
Thanks For The Info, I Got About Less Than A 1/4 Tank Of Yami Lube In There So I Should Be All Set
chadg
Yes Sir. Dump it in and rock and roll.
Thanks for the info, I was just going to ask that question. I found a dealer in my home town, $30 a gallon.
Not bad,i got my 2 cases before season when things were slow.$24galchadman said:Thanks for the info, I was just going to ask that question. I found a dealer in my home town, $30 a gallon.
