Switching Oil??
grooter
upstate newyork
:winterrul WELL WERE GETTING DUMPED ON WITH LAKE EFFECT FINALLY!!! :letitsnow SWICHING FROM YAMA-LUBE SEMI SYNTHETIC TO AMSOIL INTERCEPTOR! IS IT OK TO MIX THE TWO OILS??? IM TRYIMG TO LET IT GET DOWN AS FAR AS I CAN BUT DONT WANT TO GET CAUGHT WITH MY PANTS DOWN :o|
Yes it is ok to mix the two oils. Amsoil will for sure mix with yamalube and most other oils. I did it this year and it was fine.If you have powervalves your sled will jump up and kiss you.
do a search on oils there is alot of great info on this site.
Chad
Swithching Oils
Thanks For The Info, I Got About Less Than A 1/4 Tank Of Yami Lube In There So I Should Be All Set
Thanks for the info, I was just going to ask that question. I found a dealer in my home town, $30 a gallon.
Not bad,i got my 2 cases before season when things were slow.$24gal
