VIPER2002ER
i'm going to change my top gear to 23, i have a 68l stock chain do i need the 70l when going up one tooth
richierich
no you will be good.
MTYooper51
I would watch out when jumping up to a 23 tooth. I just took a 23 out of my '02 after junking a chaincase bearing, presumably because the chain was a little too tight. With a 23/38 (presuming you didn't change your driven gear size) ratio the chain tensioner is almost useless. Just my $.02.
VIPER2002ER
MTYooper51 said:I would watch out when jumping up to a 23 tooth. I just took a 23 out of my '02 after junking a chaincase bearing, presumably because the chain was a little too tight. With a 23/38 (presuming you didn't change your driven gear size) ratio the chain tensioner is almost useless. Just my $.02.
so change the chain to a 70l
MTYooper51
Thats what I would suggest. I didn't bump up chain length though, way better to drop two teeth on the top for hill climbing. Good luck with the 70 link though.
