vmadmax
After checking clutch alignment I'm finding that the distance is off by 3.5mm(the secondary is closer by 3.5 mm). What effect does this have on performance? Can I shim the secondary to make up the difference or does the engine have to be moved? Trying to comprehend the uncomprehendable!
kysledneck
Well on the 97's you loosen the engine bolts & adjust to spec!
Toad
I just put a new secondary on my 94' V-Max, just shim the secondary until your clutches line-up. It should have a few Shims (washers) that you can match up.
