Rambunctious
are there heavier rivits for tip on stock 2000 srx swign weights?
I am too high on rpm for top half of shiftout
WWW primary
4.5g each hole
51/43 helix
red wound only to 60 now and still pulls to 8900-9000 on 15deg day
I also added nos this year, so if more tip weight works off the nos, it will also help on the gas too (compared to stock)
i want perfect clutching off the nos
Ramb
WWW primary
4.5g each hole
51/43 helix
Ramb
you must have wrong rivet to rave at 8900 9000 on gaz or maybe that engine is not stock
Rambunctious
stock engine, except Powerinc Can, and above mentioned clutchwork
I added 4.5 rivit to inner hole last year when I did clutch work
kept stock outer rivit,
stock gearing
long travel rear
off the nos I am hitting 8400 off the line , then climbing to 8900 at the top half of shift (75mph plus)
play with throttle at this speed, can pull 8900 any time at WOT
seemed ok on previous day of 22 deg ( saw 8500-8600)
but second day was 12-15 degrees and seemed to pull more rpm
I can really feel it falling off the pwerband bacasue day one it seemed to pull
a lot better
Ramb
stock gearing
long travel rear
a lot better
Ramb
Rambunctious
to clarify
i have thsi issue without NOS
well i'm sure you don't have 4.5 rivet in both hole if u have the w-w-w yamaha spring
Rambunctious
why you say that
the rivits looked simlar size after i installed the inners (last year)
and this combo is what comes recommended by Turk and others
Ramb
Ramb
are u sure you didnt put 3.6 rivet ??
what color are those rivets ??
Rambunctious
metal color, no paint color
I bought (3) 4.5g rivits from the yamaha dealer and replaced teh inner rivits
worked great last year with a 22 top gear ( down 1 from stock)
I went back to 23 this year cause I figured teh nos will pull when needed.
but now I am high on rpm
I'm thinking the extra lugging (although slight) is pulling a slight backshift
so if there is a bigger rivit available for tip ( helps mostly top end) that it might be the fix
Ramb
Ramb
are they a kind of gold one
Rambunctious
Hauck sells 5.0,5.5,6.0 gram boldts for the weights
yeah they look black on the bench lolll not gold and what is those weight ?? 8dn-10
Rambunctious
great
so I weight them before and after tapping, and go from there
perfect
these can be change on teh sled right? easy enough to reach?
jsut use locktight
perfect
jsut use locktight
Rambunctious
8dn -20 right?
stock for 2000 srx
stock for 2000 srx
ok it was hard to see on your picture i just guess it ..... well you can pull out those weight in place but u need a drill to take them out ... i never use locktight u just rivets them in place with a vise
do you have the stock roller ?
