scotvanb
This fall I replaced all three of my powervalves, because two of them had pulled through. The cables all looked fine, and I adjusted them. For some reason since I did this, my temp. light is flashing at me when I reach about 7000 rpms. It is flashing 7 times and then a break. I know that code means something is up with the servo motor. I took the cover off the servo motor and turned down my idle below 1000 rpms to check and see if the motor is working. It seems to be fine! There really doesn't seem to be much if any lack of power, could it be an electrical issue?
