Hi Guys,
I have to replace the throttle block and was wondering if this can be done with out removing the grip. I found a post about this when I did a search but it was not for an SX. If I do have to remove the grip will the grip slide off when the rivet is drilled out?
If you have to remove the grip............. drill out the rivit and then use air pressure to blow it off.
A good blow does wonders...........
Tod
Tod
If i remember right grip has to come off..
Its Done
thanks for the replys guys. I ended up drilling out the rivet to remove the grip which was not difficult at all. I did not use air to take off the grip; I ended up just pulling it off. So I guess you could say it was a hand job instead of a blow job
.daman
Yea mine also came right off when i poped the rivet off..kcp said:thanks for the replys guys. I ended up drilling out the rivet to remove the grip which was not difficult at all. I did not use air to take off the grip; I ended up just pulling it off. So I guess you could say it was a hand job instead of a blow job.
