I have no idea why people like to take the recoil apart when the rope breaks, theres no point in it but alot of frustration on your behalf and cus words you have to make up.
Simply remove recoil from engine/sled, now get a pic tool out and flip the recoil over, you will notice the rope knot sticking thru the pulley. Using the pick tool simply pull the knot from the pulley and pull out the old rope, discard the old rope. Take your new rope and tie a knot on the end of it, heat the knot up slightly with a burnzamatic torch to keep it from slipping. Heres what makes this so simple, now that the rope has broken all the twist or recoil pull is out of the spring, so you simply grasp the pulley and spin it in the same direction the rope comes out, turn the pulley a good 5 times, complete 360 degree circles, this preloads the spring so it will pull the rope back in. Now grasp the pulley to keep it from spinning back( I use a small welding clamp and gently clamp the pulley to the housing, making sure I align the holes up with outer housing) and insert the rope to the recoil pulley knot hole and align the pulley up so the rope will come out the hole in the recoil housing, pull the rope till the knot seats in the pulley hole. Let the string recoil back into the housing keeping a good grasp on the end of it, if you wanna play it safe tie a knot in it near the handle end and check the recoil action when you pull the rope in and out, if its not retracting the rope all the way you need more spring tension, simply remove rope in reverse order and spin the pulley back a couple more times then before. There is no need to ever remove the pulley/spring from the recoil unless the spring is broken or the pulley is broken!
