Concept Carbon
ok im going to adjust my pvs tommorrow, from what ive read you run your idle down to 900 and adjust them for 2.5mm. so i loosen the 2 alens the measure 2.5mm with a dial caliper.
just wanted to double check im doin gthis write before i mess something up.
thanks.
also feel free to post your methods of doing this.
thanks.
Use two 2.5mm allen wrenches as a gauge
also did you search this.LOTS of info. lol
Concept Carbon
yeah i seached like crazzy but i get alot of srx info, and jsut wanted to double check, also there is almost to much info to sif tthrough thought it would be easyier to just ask.
thanks so 2.5 is good for a viper.
lol searched but never even noticed the post lik e3 below this one, whenever i search i get cleaning methods.
My Bad i was thinking srx lol, i'd say yea but not 100%.Concept Carbon said:thanks so 2.5 is good for a viper.
EricMichael
question for you guys, I see that you can adjust your valves by measuring 2.5 mm gap, and can also measure by feeling in the exhaust port to make sure they are flush. Whats the diffrence here, does the 2.5 mm measure how much tention is on the cable?To do it either way you have to adjust them from the servo..so is it good to do it both ways to make sure cable tention and valve adjustment is correct?
Concept Carbon
im goin gto do what yamaha and mr viper recomend which is measure 2.5mm, check about 3 posts below they go into detail there.
You could,it's all up to what you want to do,i'm still undecided.EricMichael said:so is it good to do it both ways to make sure cable tention and valve adjustment is correct?
i may do the yamaha way then pull pipes and see how far off they are..
flying yami
the yamaha way is right on when you check with the pipes off.
K....flying yami said:the yamaha way is right on when you check with the pipes off.
