chaincase
gates26
ontario
Does anyone know if the thick spacer in the chaincase goes behind the top gear or the bottom gear ?
99 srx 700
Check out this link , you will have to select "track drive 2" from the drop down menu. Then I think it will show you the info you need. After you go there, save that page to your favorites. You can veiw all of the micro fisch's for your sled from there. Hope this helps. -Ed :yam:
