Supercharged Vector Mountain
Srxspec
Your #1 performance shop!
Menno, SD
Website
www.ulmerracing.com
What was another project sled a while back here at Ulmer Racing!
Have a pile of parts here to put on it and a few more parts yet still to come!
Pile of parts consists of:
-MPI Supercharger
-Lightweight hood
-Timber Sled Barkbuster Front End
-Lightweight seat
-Slydog Powderhound skis
-Fox Float front shocks
-Excell Motorsports high flow header
-Excell Motorsports Mountain Lite exhaust
-Timber Sled drop brackets
More pictures to come as the progress continues!!
Lexan Hood:
High Flow Header:
Supercharger:
Just a picture of the hole required to be drilled through the Delta Box.
Picture of the special tool you need to tighten the supercharger shaft nut to torque it to 40 ft lbs.
Supercharger top bracket (I had to loosen the top oil line and rotate the line slightly so the bracket fit correctly.
Front View.
CDI position.
Modification of the battery bracket. It didn't quite fit how I liked so I modified it slightly for a better fit.
Rivets that must be removed for Timber Sled drop brackets and removal of OEM drop brackets
Stock drop brackets & weight
Timber Sled drop brackets & weight (8 lbs difference)
Gauges
Just did the very first Mountain Lite exhaust on a Vector from Excell Motorsports!
-Stock exhaust (plus all the nuts, bolts, side covers, etc) = 21 lbs
-Excell Motorsports (with all mounting hardware) = 5 lbs
16 lbs lighter total!
Ryan, I haven't had the whole sled on the scales yet. I have been tracking how much we've been taking off piece by piece and we're up to 40 lbs now. I'm installing a EZ Ryde suspension in it this weekend (supposed to be 27 lbs lighter) and should have a Barkbuster Front End next week sometime (supposed to be 14 lbs lighter), I'm hoping we can be around 80-90 lbs lighter than stock with 200+ hp!
