Took my SRX out for a run in the fields beside my house.It is really wet and soft the snow.It was about 4 Celcius here today and noticed as I have noticed before.When I really pin it,I am getting a bog or hesitation,feels like engine won't open up ,let go throttle and punch it again and good.This is most likely what you guys call a lean bog.I went up 2 jet sizes on my carbs a while back.Left the pilots stock at 42.5.Shouldn`t I change them to.2001 SRX`s have 40 pilots with the same jetting as I.My fuel screws are 1.5 turns open.Even a month ago when the temps were slightly below 0,I was getting the same thing happening.When I pin it really hard from a stand still,all of a sudden it is like it is starving for fuel or engine won,t open up unless I flip the throttle a few times and then punch it.Sometimes the DSC or the DCS(whatever you call it) would come on,telling me I am leaning out.
Question is ,if I go from 42.5 pilot to 40 pilot,what am I exactly doing...increasing or decreasing.If I am jetted 2 times higher then pilots should be changed and the fuel screws maybe opened more.Just need to know that I am doing the right adjustements to the carbs.If I follow the specs for the 2001 SRX,it calls for 40 pilots then.I`ll have to get the carbs off this summer and go thru them.Float specs,and cleaning really good.Synchronize the carbs also would be a must to.I will check my reeds,may replace them with Carbon Tech ones.And 1 more question.Can the head gasket mod be done to an SRX,or am I just looking for a problem.Don`t even know what they have for a head gasket on them.
