how to lower the rear suspension on the srx
Good luck trying to chain it down. I tried it and there is no room to get you hands in to chain it after you suck it down to ride height. If it is just temporary just do your limiters and tie the front shocks down.
Get some rubber belt/strap that is roughly 1" wide. Put a cross shaft between the rails right below the rear shock mount. Run your under the shock (under the shock eyelet) down to the cross shaft that you installed below.
