ExpertXViper
Alright last night I FINALLY got my sled finshed after all this time. I started out by breakin in with the primary only. 1st start I ran her for a good 25min never letting it rev at the same rpms for long. Stopped to let her cool a bit and started it 3 times after that using the same process. Then I jacked it up and ran with the belt on to get some drag. NO PROBLEMS........Started it this morning, started on the first pull, let it sit at full choke for 2 or 3min, went to half for about 10min, then no choke. When I went to no choke the IDLE kicked up and when I went to grap some throtthle it bog immeditly. I let the idle screw out competely, so the idle would drop, but NO LUCK. Set the idle screw where it was and put it back to half choke and it revs and idles fine. So what would cause this????
