..SNAKEBIT..
so what you think Joe Gibbs, Penske, etc........ buy their spark plugs??
SXRYAN
John should hook me up with some plugs, my truck takes 16!!
I don't know about Joe Gibbs or Penske!!!! Austin Coil grew up in my neighborhood... it's a neighborhood joke!!!!
montynormand
I've had this information from a email: thought it fit in here:
* Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
* THE BOTTOM LINE: Assuming all the equipment is paid off, the crew worked for free, & for once, NOTHING BLOWS UP, each run costs an estimated $1,000 per second.
Putting this all into perspective:
You are driving the average $140,000 Lingenfelter twin-turbo powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged & ready to launch down a quarter-mile strip as you pass. You have the advantage of a flying start. You run the
'Vette hard up through the gears and blast across the starting line & pass the dragster at an honest 200 MPH. The 'tree' goes green for both of you at that moment.
The dragster launches & starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums & within 3 seconds the dragster catches & passes you. He beats you to the finish line, a quarter-mile away from
where you just passed him. Think about it - from a standing start, the dragster had spotted you 200 MPH & not only caught, but nearly blasted you off the road when he passed you within a mere 1320 foot long race!
That's acceleration!
'02 SRX700
That Is Awesome
redsnake3
that is crazy, bet my viper would give him a good go tho'. lol
the thing that gets me is the 44amps for each plug. holy crap batman!!!
The other cool thing to think about is how many crank revolutions actually occur in the 1/4 mile run. Just for example (cause I can't remember the real numbers) 9000 RPM = 150 RPSecond. in an 8 second run that means the crank only rotates 1200 times. Do some cyphering with different max RPM's and times.
