Orv
- Sep 3, 2005
- Crosslake, MN 56442
- www.weighttrainingworkouts.com
Question:
How do remove the Primary Clutch?
Do I need a clutch Puller?
Thanks in advance!@!
Jim
Jim
Yes, you need a puller.
98srx6
You can get one from Rich Motorsports here on the board for a reasonable price. Also, do some research on how to use the puller before trying to pull your primary using it.
FuzzButt
While your at it add the holder to your purchase. It makes it so much easier to keep it from rotating. Well worth the additional cost. Basically with the holder you can use standard hand tools on the puller and not beat up your primary rigging something to keep it in place.
where's a good place to score one fuzz?, last time i priced one i gotFuzzButt said:While your at it add the holder to your purchase.
sticker shock!!!!
FuzzButt
I picked one up at the Novi show for under $30. A good puller is about the same price.
You can probably make one if your good with steel.
Here is my holder. I added the tape cause it was easier than deburing.
I see, holds good??? thanks for the pic.
FuzzButt
Holds the primary in either direction and is long enough to rest under/on top of the secondary's attachment bolt.
It's 1/8" plate and looks like it was stamped out. I can take some measurements. I think it should be pretty easy to make a "C" shaped holder like this.
thanks fuzz thats ok i'll just look for one..
