Sleepy
Good Day Everyone; Just joined the club and looking forward to chatting. I purchased a 02 viper last winter and love the sled. It ran greatlast winter except the track was shot. I replaced it this year with a pre studded ice ripper and love it. Now I'm having oil problems. I did about 75 miles and used a full oil res. Not good. It is currently in the shop, but iwouldn't mind some additional info. I thought after I dropped it off that I may have put the exhaust valves back incorrectly when I cleaned them. But that is all I can figure out.
Any ideas?
Sleepy
Any ideas?
Sleepy
just letting you know....
Also you can try a search on things too lots of info on here about vipers.
and there's a viper specific thread to post in too this one is really not
for trouble shooting..
woolyviper
"Somtimes the oil cable can pull out of it's slot(here,here)check that then also,"
what he said -
what he said -
Sleepy
Thanks for the advice. We also found cracks in the exhaust pipe(on either side,top and bottom of the middle pipe off the block). We make the other adjustments and hope for the best.
Sleepy
Sleepy
viperking
my viper had the oil cable pull out of it's place and it guzzled oil like yours
blue missile
wheather or not yopu put the valves in wrong it will not affect your oil consumption. they go bevel up. did you have you're carbs off? check what the others have pointed out. also if the oil pump goes bad i believe they go to full stroke?
S.S.Viper
Ah...what perfect timing for this thread...I thought I was goin crazy..or my pump was froze on wide open...Purchase 1 jug of Blue Marble...rode 240miles...1/4 left in the jug...arghhhh...saw my cable was pulled just like mentioned above...whew...Thought I mighta had serious problems...cheers
Millinocket Rocket
started full, put 217 miles on this past weekend and when i got home i could only fit 1 quart in (also blue marble) in my viper
Sounds good..how much gas did you burn in them 217?Millinocket Rocket said:started full, put 217 miles on this past weekend and when i got home i could only fit 1 quart in (also blue marble) in my viper
yamaholic22
blue missile said:wheather or not yopu put the valves in wrong it will not affect your oil consumption. they go bevel up. did you have you're carbs off? check what the others have pointed out. also if the oil pump goes bad i believe they go to full stroke?
What? The powervalves go with the big bevel down and the little chamfer to the top.
LOL..damn holic i missed that one...YES bevel DOWN!!!!!!yamaholic22 said:What? The powervalves go with the big bevel down and the little chamfer to the top.
