too much oil
Sleepy
Kemptville, Ont. Can
Good Day Everyone; Just joined the club and looking forward to chatting. I purchased a 02 viper last winter and love the sled. It ran greatlast winter except the track was shot. I replaced it this year with a pre studded ice ripper and love it. Now I'm having oil problems. I did about 75 miles and used a full oil res. Not good. It is currently in the shop, but iwouldn't mind some additional info. I thought after I dropped it off that I may have put the exhaust valves back incorrectly when I cleaned them. But that is all I can figure out.
Any ideas?
Sleepy
Welcome!!!!!!
Somtimes the oil cable can pull out of it's slot(here,here)check that then also,
1-adjust idle
2-set throttle end play(here) to 2mm
3-then set oil pump gap(here,here) to 22mm
do thos in that order..
just letting you know....
Also you can try a search on things too lots of info on here about vipers.
and there's a viper specific thread to post in too this one is really not
for trouble shooting..:)
"Somtimes the oil cable can pull out of it's slot(here,here)check that then also,"
what he said -
Thanks for the advice. We also found cracks in the exhaust pipe(on either side,top and bottom of the middle pipe off the block). We make the other adjustments and hope for the best.
Sleepy
wheather or not yopu put the valves in wrong it will not affect your oil consumption. they go bevel up. did you have you're carbs off? check what the others have pointed out. also if the oil pump goes bad i believe they go to full stroke?
Ah...what perfect timing for this thread...I thought I was goin crazy..or my pump was froze on wide open...Purchase 1 jug of Blue Marble...rode 240miles...1/4 left in the jug...arghhhh...saw my cable was pulled just like mentioned above...whew...Thought I mighta had serious problems...cheers
Millinocket Rocket said:
started full, put 217 miles on this past weekend and when i got home i could only fit 1 quart in (also blue marble) in my viper
Sounds good..how much gas did you burn in them 217?
What? The powervalves go with the big bevel down and the little chamfer to the top.
