Help guys....
Coles_55
Eagle, WI
Well I was riding last night and kinda hit a stump, its not like I drilled it at 80, but I was going about 15-20 and now my speedo doesnt work??
What happened??? Everything else works, tach, fuel, all gauges so whats the deal??
probably broke the pin that goes into the driveshaft, check under your secondary sheave there you will find there is a end of the wire, loosen the 3 nuts and check if the pin is ripped in 2...bet 100bucks on that will be your answer
