can you just ground the wire to the frame, is the image just you splicing into the ground on the temp sensor.
the picture above was of my sled. i had wired it so i could either run the temp gauge to the box or to the guage and install the resistor in the remaining plug. i cut a temp sending unit apart and sodered the resistor to it, then covered it with silicone so it would just plug in to the plug like the sending unit. after testing different things, i found it didnt matter which one was bypassed, the guage would show an overheat(i made a plug to simulate the ohms of a temp sender that was too hot). why i said to just run the wire through the resistor and then just to ground is to save you all the trouble i already went through.
also stock viper comes with 156.. jets and srx is 148..., 148..., 150,
vipers run bigger jets because they are vented to the air box. srxes vent under the motor. this effects mid range and top end jetting. the end result is the same. just two different ways to get there. just chose one and use it. as for piped vipers using large jets(165) this is because they are using gas as a coolant for the piston
how come the srx jets are so small? refer above
why do you have to get a larger jet for the viper to run srx pipes?refer above
If I get my domes machined so they are all 24cc, would 157.5 157.5 158 mains and 42.5 pilots sound right?
