rear suspension and new belt??
700XT
NH
first off, I put a new belt on a week or so ago, and its sqeels at idle. is this normal or is something out of alignment? Second thing, I bent the rear track adjustment bolt and one Idler wheel fell off doing jumps this weekend so i'm in the process of replacing them. while under there I decided to check the rest of the wheels and tgrease things up. well I noticed that there is side to side play in the W arm top mounting bolts(about 3/16 inch). not normal I'm guessing. Is it just some shims I need to replace or something more involved?
Thanks Shawn
While the belt is sqweeling push the secondary clutch towards the moter than pull it towards the outside of the sled if the noise stops add a shim or remove for better aligment.If it does not stop adjust the secondary shim bolts.As for the play the plastic collers have a washer molded in them and are probibly long gone.
