700triple
I want to get a more agressive dual angle helix for my sx 700 for drag racing. My gearing is 20/40 and the primary works really good. I run the stock 45 degree helix and 60 degree and dosen't shift enough. I want the best set-up to do 0-600ft. I know it can be alot better. What do you think about 54/44? Should it be better with 59/43? Thanks for help
kysledneck
43/35 Advant-edge! I run 40 20 gearing stock weights, 4.5 inner 3.6 outer, Blk/ white spring 15mm rollers 3&3 in the secondary
whats in the primary as far as weights and spring?
700triple
I run 8-BU-00 and Y-S-Y spring. It take no time to get the 9000rpm but still rev and did'nt shift as I want.
clutching
sent you a pm
sent you a pm
700triple
What do you think about a roller secondary 56-46 and 56-44 for 200$ cnd?
